[postgis-devel] Build ST_GeomFromGeoJSON
maplabs at light42.com
Sat Nov 19 14:52:34 PST 2011
maybe I am missing something basic...
(Debian Wheezy, Pg 9.1, postgis_trunk rev 8189)
sudo apt-get install libjson0-dev
## package shows installed /usr/include/json/ and
/usr/lib/libjson.so .so.0 .so.0.0.1 .a .la
make clean; ../configure ; make; sudo make install
createdb test2; ...
\df st_geomfrom*
st_geomfromgeojson
select st_astext( st_geomfromgeojson( st_asgeojson( 'POINT(1 1)')));
## fail ##
make clean
./configure --with-jsondir=/usr
WARNING: unrecognized options: --with-jsondir
psql -c "drop database test2"
createdb test3; ...
## fail
-Brian
On Thu, 17 Nov 2011 16:19:59 -0800, Paul Ramsey <pramsey at opengeo.org> wrote:
Thanks so much Kashif. I have applied your patch and added some guards
> to it's possible to compile without JSON-C supoprt, and a very minimal
> number of regression tests (should be expanded to cover all geometry
> types).
> Yours,
> Paul
> On Mon, Nov 14, 2011 at 8:10 AM, PostGIS <trac at osgeo.org> wrote:
> > #376: Add ST_GeomFromGeoJSON
> > Reporter: colivier | Owner: colivier
> > Type: enhancement | Status: new
> > Priority: medium |
> Milestone: PostGIS 2.0.0
> > Component: postgis | Version: trunk
> > Keywords: GeoJSON import ST_GeomFromGeoJSON |
> > Comment(by kashif):
> > I have attached a patch to the current svn for testing.
> > Ticket URL: <http://trac.osgeo.org/postgis/ticket/376#comment:4>
> > PostGIS <http://trac.osgeo.org/postgis/>
> > The PostGIS Trac is used for bug, enhancement & task tracking, a
> user and developer wiki, and a view into the subversion code
> repository of PostGIS project.
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
