[postgis-devel] Build ST_GeomFromGeoJSON
maplabs at light42.com
Sat Nov 19 18:49:53 PST 2011
perhaps
AC_CHECK_LIB( [json], ... )
and
AC_CHECK_HEADERS( [json.h] )
/me stab in the dark
-Brian
On Sat, 19 Nov 2011 15:46:38 -0800, Paul Ramsey <pramsey at opengeo.org> wrote:
./autogen.sh to regenerate ./configure
> p
> On Sat, Nov 19, 2011 at 2:52 PM, <maplabs at light42.com> wrote:
> > maybe I am missing something basic... (Debian Wheezy, Pg 9.1, postgis_trunk
> > rev 8189)
> > sudo apt-get install libjson0-dev
> > ## package shows installed /usr/include/json/ and /usr/lib/libjson.so
> > .so.0 .so.0.0.1 .a .la
> > make clean; ../configure ; make; sudo make install
> > createdb test2; ...
> > \df st_geomfrom*
> > .. st_geomfromgeojson
> > select st_astext( st_geomfromgeojson( st_asgeojson( 'POINT(1 1)')));
> > ## fail ##
> > make clean
> > ./configure --with-jsondir=/usr
> > WARNING: unrecognized options: --with-jsondir
> > psql -c "drop database test2"
> > createdb test3; ...
> > ## fail
> > -Brian
> > On Thu, 17 Nov 2011 16:19:59 -0800, Paul Ramsey
> > Thanks so much Kashif. I have applied your patch and added some guards
> >> to it's possible to compile without JSON-C supoprt, and a very minimal
> >> number of regression tests (should be expanded to cover all geometry
> >> types).
> >> Yours,
> >> Paul
> >> On Mon, Nov 14, 2011 at 8:10 AM, PostGIS <trac at osgeo.org> wrote:
> >> > #376: Add ST_GeomFromGeoJSON
> >> > Reporter: colivier | Owner: colivier
> >> > Type: enhancement | Status: new
> >> > Priority: medium | Milestone: PostGIS
> >> > 2.0.0
> >> > Component: postgis | Version: trunk
> >> > Keywords: GeoJSON import ST_GeomFromGeoJSON |
> >> > Comment(by kashif):
> >> > I have attached a patch to the current svn for testing. >
> >> > Ticket URL: <http://trac.osgeo.org/postgis/ticket/376#comment:4>
> >> > PostGIS <http://trac.osgeo.org/postgis/>
> >> > The PostGIS Trac is used for bug, enhancement & task tracking, a user
> >> > and developer wiki, and a view into the subversion code repository of
> >> > PostGIS project. > _______________________________________________
> >> > postgis-devel mailing list
> >> > postgis-devel at postgis.refractions.net
> >> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
