[postgis-devel] [PostGIS] #1317: [raster] CASE expression causes ST_MapAlgebra for 2 raster to fail
trac at osgeo.org
Mon Nov 21 11:23:04 PST 2011
Reporter: pracine | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
This query:
SELECT ST_MapAlgebraExpr(ST_AddBand(ST_MakeEmptyRaster(4, 4, 0, 0, 1, 1,
0, 0, -1), '32BF'::text, 6, -1), 1,
0, 0, -1), '32BF'::text, 4, -1), 1,
'CASE WHEN rast2 > 0 THEN rast1 / rast2 ELSE NULL
END'::text,
NULL::text,
'UNION'::text,
NULL::text,
NULL::text,
NULL::double precision)
produces this error"
ERROR: column "rast2" does not exist
LINE 1: SELECT (CASE WHEN $2 > 0 THEN $1 / RAST2 ELSE NULL END)::dou...
QUERY: SELECT (CASE WHEN $2 > 0 THEN $1 / RAST2 ELSE NULL END)::double
precision
********** Error **********
SQL state: 42703
There seems to be a problem when parsing CASE expressions...
I was testing ST_Union()...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1317>
