[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a view and AddRasterColumn enforce more
PostGIS trac at osgeo.org
Tue Nov 22 07:07:09 PST 2011
 Reporter:  robe            |       Owner:  robe
     Type:  task            |      Status:  new
 Priority:  high            |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by pracine):
 So if I understand well some properties are defined when defining the type
 of the geometry column (this is the typmod) and more properties can be
 added to the view by defining constraints on the table? Can we
 list/differenciate what should be defined using the typmod and what should
 be defined using the constraints?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1319#comment:1>
