[postgis-devel] ST_MapAlgebraExpr(): Raster aggregates?
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Wed Nov 23 06:05:43 PST 2011
Thanks for this feedback Tom.
Could you tell us more on 1) What you do exactly? 2) The characteristics of your dataset (size, pixeltype) and the performance of ST_Union?
You are the first on earth one to do raster aggregation of real rasters in a spatial database!
I developed and tested ST_Union only on 100x100 rasters...
Pierre
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of Tom van Tilburg
> Sent: Wednesday, November 23, 2011 8:54 AM
> To: postgis-devel at postgis.refractions.net
> Subject: Re: [postgis-devel] ST_MapAlgebraExpr(): Raster aggregates?
> Tested and working as expected.
> This is a very usefull addition. Thanks for the effort all!
> Tom
> On 21-11-2011 22:28, Pierre Racine wrote:
> > Tom,
> > ST_Union is.... Fixed! Thanks to Bborie.
> > Just update your source, create a fresh database (or get rid of the
> > old MapAlgebra4Union) and execute everything up to the tests at the
> > bottom of the file. Have a visual look at the test using OpenJump or
> > QGIS (they were written for OpenJump with the ST_Asbinary() converting
> > the vectorization of the result.)
> > Let us know about your tests.
> > For those who might be interested ST_Union() is the prototype of a
> > function aggregating overlapping rasters into a single raster. It does
> > pretty much the same thing as the ST_Union(geometry) aggregate but for
> > rasters. Since it is an AGGREGATE you can use GROUP BY to aggregate
> > based on the value of a column. You have to specify how you want
> > raster values to be aggregated. I implemented shortcuts to MAX, FIRST,
> > LAST, COUNT, SUM, RANGE and MEAN, but you can define your own
> complex
> > aggregator by defining a STATE expression, a TEMPORARY and a FINAL
> > expression. Have a look at the specifications in
> > http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWorking03
> > And have fun!
> > Pierre
> >> [mailto:postgis-devel- bounces at postgis.refractions.net] On Behalf Of
> >> Tom van Tilburg
> >> Sent: Monday, November 21, 2011 5:05 AM
> >> To: PostGIS Development Discussion
> >> Pierre,
> >> Thanks a lot for pointing me out this.
> >> I've looked in to the plpgsql code but I'm afraid my current
> >> knowledge (or time) doesn't allow me to contribute code.
> >> However, I tested the prototype of ST_Union. It appears to be rather
> >> buggy (typo's). Has it ever been applied/tested?
> >> (eg: 'ERROR:  parameter name "p_nodata1expr" used more than once. '
> >> seems to be copy paste error.)
> >> Chrs,
> >>    Tom
> >> On 18-11-2011 16:54, Pierre Racine wrote:
> >>> I would even suggest you write a plpgsql prototype for
> >>> ST_UnionToRaster()
> >> based on the specifications.... ...if you have time for sure.
> >>> I would be glad to add it in the plpgsql/script on the trunk. It
> >>> then becomes the
> >> reference for a future C implementation.
> >>> Pierre
> >>>> Of Pierre Racine
> >>>> Sent: Friday, November 18, 2011 10:39 AM
> >>>> Tom,
> >>>> Look at the plpgsql prototype of ST_Union(raster) in
> >>>> http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/
> >>>> st
> >>>> _union.sql
> >>>> Have a look also at the specifications of
> >>>> ST_UnionToRaster(geometry,
> >>>> val) in
> >>>> Everything is based on ST_MapAlgebraExpr(raster, raster, expr) and
> >>>> should do exactly what you want.
> >>>> It should be ok for producing low resolution raster as our first
> >>>> implementation of ST_MapAlgebraExpr(raster, raster) process pixel
> >>>> by pixel. Higher resolution will need an optimized version of
> >>>> ST_MapAlgebra(raster, raster) copying large areas of raster values
> >>>> when possible (it is exactly what we need for unioning two rasters
> >>>> efficiently). We started to make a plpgsql prototype for this
> >>>> optimized version but it is not finished
> >>>> (http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql
> >>>> /s t_mapalge bra_optimized.sql). I guess we will need some funding
> >>>> to make it happen...
> >>>> Let me know about your experiments...
> >>>> Pierre
> >> _______________________________________________
> >> postgis-devel mailing list
> >> http://postgis.refractions.net/mailman/listinfo/postgis-devel
