[postgis-devel] [PostGIS] #1322: lwgeom_from_wkt doesn't initialize LWGEOM.bbox
trac at osgeo.org
Wed Nov 23 08:11:31 PST 2011
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
While adding tests for GML output I found that an LWGEOM constructed via
lwgeom_from_wkt is giving a LWGEOM.bbox with value 0x8. Sounds like an
uninitialized box. Is it meant to be filled ? If not it should be NULL, I
guess.
Beside, the WKT is a 2 points LINESTRING, shouldn't it have a bounding box
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1322>
