[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a view and AddRasterColumn enforce more
PostGIS trac at osgeo.org
Wed Nov 23 10:49:18 PST 2011
 Reporter:  robe            |       Owner:  robe
     Type:  task            |      Status:  new
 Priority:  high            |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 Basic raster_columns view.  Will need to add constraint checking functions
 to check for scalex, scaley and bandtype.
 CREATE OR REPLACE VIEW v_raster_columns AS
         SELECT
                 current_database()::character varying(256) AS
 r_table_catalog,
                 n.nspname::character varying(256) AS r_table_schema,
                 c.relname::character varying(256) AS r_table_name,
                 a.attname::character varying(256) AS r_raster_column,
                 COALESCE(postgis_constraint_srid(n.nspname::text,
 c.relname::text, a.attname::text), (SELECT ST_SRID('POINT(0
 0)'::geometry))) AS srid,
                 -- scalex double precision
                 -- scaley double precision
                 -- bandtype[] text[]
         FROM
                 pg_class c,
                 pg_attribute a,
                 pg_type t,
                 pg_namespace n
         WHERE t.typname = 'raster'::name
                 AND a.attisdropped = false
                 AND a.atttypid = t.oid
                 AND a.attrelid = c.oid
                 AND c.relnamespace = n.oid
                 AND (c.relkind = 'r'::"char" OR c.relkind = 'v'::"char")
                 AND NOT pg_is_other_temp_schema(c.relnamespace);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1319#comment:7>
