[postgis-devel] ST_MapAlgebraExpr(): Raster aggregates?
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Thu Nov 24 07:42:27 PST 2011
Tom,
> An image of just over 4 million pixels with 11 discrete raster values
> takes around 1 minute on my 2.3 Ghz, 6Gig. mem. laptop.
> I can sent the corresponding SQL if you like.
I would be glad to have a look at your SQL.
> 2) Glueing together tiled rasters
> Not sure if this is the right tool for it though, but we are calculating
> average pixel values within an overlaying polygon. When a polygon
> overlaps 2 or more raster tiles, we need to union the tiles first to
> make a proper average.
> The complete calculation works as follows:
> (ST_SummaryStats(
> (ST_Union(
> ST_MapAlgebraExpr(
> ST_AsRaster(a.geom, b.rast, '32BF')
> ,b.rast
> ,'rast2', '32BF','INTERSECTION','0','0',0
> )).rast
> )).mean As avg_height
> Doing this calculation with 600,000 polygons over a 5m grid for all of
> the Netherlands takes over 8 hours.
Did you try the vector approach to do that? Like in the tutorial:
http://trac.osgeo.org/postgis/wiki/WKTRasterTutorial01
The rules to choose one approach over the other is:
-If your vector coverage is sparse the vector method is generally faster (your raster coverage has to be tiled small)
-If your vector coverage has no gap (like a grid covering your study area), the technique you used is the right one.
Today I will post a function helping to summarize the average and other weighted stats when applying the first technique.
Pierre
