[postgis-devel] Caching Double-based Boxes
Sandro Santilli
strk at keybit.net
Thu Nov 24 23:34:20 PST 2011
On Fri, Nov 25, 2011 at 08:11:06AM +0100, Nicklas Avén wrote:
> I don't know if "my" issue has any practical impact. But just so I
> understand.
> I have never thought about if before, but from this discussion I
> understand that the boxes is stored in two places. Both the index and
> together with the geometry. Am I right?
Yes, you're right.
> Just some very naive thoughts.
> We have no access to the index bbox to use in the functions?
Not in a straightforward way, no.
> There is nothing that points to the index key from the geometry? Is it
> so. It is the same reason we can't get the extent from a table from the
> index?
I'd think you could, altought not easily.
But the main reason why you don't want to do that is that you don't
want to be _forced_ to have an index in order to process values.
Note that Geometry values could also be literal, never touching a table.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
