[postgis-devel] About BOXES
Sandro Santilli
strk at keybit.net
Fri Nov 25 08:50:51 PST 2011
On Fri, Nov 25, 2011 at 08:39:48AM -0800, Paul Ramsey wrote:
> On Fri, Nov 25, 2011 at 8:18 AM, Sandro Santilli <strk at keybit.net> wrote:
> > Can we get rid of them all ? Why not ?
> There are use cases for boxes, so keeping one makes sense. There are
> also uses of boxes embedded in client code, as you note index queries
> were documented against a 'BOX3D' example for a very long time, even
> when the index ops themselves were happening in GEOMETRY.
> The case for BOX3D is that it's a known external interface. The case
> against it is that it has no SRID. We could upgrade the backend
> storage for BOX3D to support SRID and enrich the text representation
> with the "SRID=999;" hack. That would have the advantage of not adding
> yet more boxes, and the disadvantage of keeping the odd "BOX3D" name
> for what might sometimes be a 2D and sometimes a 4D box.
Another idea:
1) keep BOX3D but deprecate it
(have it raise WARNING messages on canonical input...)
2) add a new type to which BOX3D implicitly cast
( and returned by ST_Srid(BOX3D) )
This could solve the name issue.
Then:
3) drop all the other boxes (save gidx, being internal)
4) have st_extent return the new type
And maybe, if entusiasm gets you:
5) have bbox-oriented operators be defined on the new type
6) provide implicit casts from each type to the new bbox type
7) drop loads of operators duplication
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
