[postgis-devel] [PostGIS] #1066: [raster] raster crashes server with arbitrary tests
trac at osgeo.org
Fri Nov 25 09:17:37 PST 2011
Reporter: robe | Owner: pracine
Type: defect | Status: reopened
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
I'm still able to crash the server even on my 32-bit box. I'm wondering
if its just a share case of endurance because as the tests go I can feel
my box getting slower and slower till I can barely log into it anymore.
Attached is the full test. Bborie, can you run the full sql tests on your
dev box and see if it eventually crashes. A lot of tests won't complete
because I haven't revised the script to handle things like regprocedure
etc so don't worry about it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1066#comment:9>
