[postgis-devel] [PostGIS] #1246: Can't make check under mingw
PostGIS trac at osgeo.org
Fri Nov 25 21:04:39 PST 2011
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by pramsey):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Yes, the consequence will be that when run under plain sh it won't work.
 But I'll wait until I have a chance to do that again (Solaris) and then
 fix the bashisms instead of changing the shell. r8243
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1246#comment:3>
