[postgis-devel] [PostGIS] #1335: ST_AddPoint returns incorrect result on Linux
trac at osgeo.org
Mon Nov 28 19:32:22 PST 2011
Reporter: realityexists | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by darkblueb):
64bit Linux, AMD
psql (9.0.4)
Type "help" for help.
ct_test_09nov11=# select postgis_full_version();
POSTGIS="1.5.3" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.8" USE_STATS
(1 row)
ct_test_09nov11=# select st_astext(st_addpoint(
ct_test_09nov11(# st_geomfromtext( 'linestring(20 20,30 30,40
40)',4326),
ct_test_09nov11(# st_geomfromtext( 'POINT(10 10)',4326),
ct_test_09nov11(# 0));
st_astext
LINESTRING(10 10,20 20,30 30,40 40)
(1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1335#comment:4>
