[postgis-devel] Caching Double-based Boxes
maplabs at light42.com
Tue Nov 29 07:31:25 PST 2011
I found it unexpected (and disconcerting) that the run times were
always so much better immediately after a postgres restart. (3rd test
run) -Brian
On Tue, 29 Nov 2011 15:11:06 +0000, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
On 29/11/11 14:14, Paul Ramsey wrote:
> > Well, two things (and notice to reader, we're discussing the doublebox
> > spike here):
> > - on the side of expected slowdown (systematic problem), we're pushing
> > twice as much data through the pipes (reading cached double instead of
> > cached float) to get the answer we want
> True, but I'd expect this effect to be minimal or perhaps a couple of
> percent at most.
> > - on the side of the unexpected slowdown (operator problem (Paul
> > error)), in order to do the comparisons between the cache keys
> > (doubles) and the index keys (floats) the cache keys now all have to
> > be converted to floats before the comparison so there's an extra step
> > in there that doesn't exist in the pure-float (cached float and float
> > indexes) implementation
> Now this might go some way to explaining some of it, although again
> most of this is speculation without a profile.
> ATB,
> Mark.
> -- Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
