[postgis-devel] GBOXF
Sandro Santilli
strk at keybit.net
Tue Nov 29 13:51:25 PST 2011
On Tue, Nov 29, 2011 at 03:24:59PM +0000, Mark Cave-Ayland wrote:
> >>My feeling is that if we use floats then we minimise the usefulness
> >>of the cache because it reduces the number of use cases that it
> >>could be used to optimise (and I'm fairly sure that some functions
> >>will assume that the second predicate in the paragraph above is
> >>true, and therefore give wrong answers in certain cases).
> >Would be useful to have a few of these use cases listed here.
> >The only one I can think about would be using&& to really check
> >for equality of points.
> Another case to think about would be GROUP BY, which works by
> performing an equality comparison between bounding boxes - again,
> two very similar yet distinct geometries could be considered equal.
This is also true for two very different geometries yet having
the same bounding box, so doesn't seem a good example to me.
Ie:
LINESTRING(0 0, 10 0, 10 10)
LINESTRING(0 0, 10 10)
I guess you were referring once again only to points ?
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
