[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with ApplyRasterConstraints and expand # of constraints on raster columns
PostGIS trac at osgeo.org
Wed Nov 30 02:56:24 PST 2011
raster columns
 Reporter:  robe            |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by mloskot):
 Replying to [comment:22 dustymugs]:
 > I believe the column "regular_blocking" should be renamed to
 "same_alignment"
 > as it is an analog to ST_SameAlignment.
 AFAICT from the current docs on ST_SameAlignment, the regular_blocking is
 not the same concept.
 The regular_blocking flag indicates if tiles in a table/coverage form a
 regular rectangular grid, or not.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1319#comment:26>
