[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with ApplyRasterConstraints and expand # of constraints on raster columns
PostGIS trac at osgeo.org
Wed Nov 30 07:29:09 PST 2011
raster columns
 Reporter:  robe            |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by pracine):
 Replying to [comment:26 mloskot]:
 > Replying to [comment:22 dustymugs]:
 > > I believe the column "regular_blocking" should be renamed to
 "same_alignment"
 > > as it is an analog to ST_SameAlignment.
 > AFAICT from the current docs on ST_SameAlignment, the regular_blocking
 is not the same concept.
 > The regular_blocking flag indicates if tiles in a table/coverage form a
 regular rectangular grid, or not.
 samealignment is necessary but not sufficient. Regularlyblocked also needs
 samewidth, sameheight, hasnogaps and hasnooverlaps. I am pretty confident
 that those 5 condition makes regular blocking. See Objective FV.20 in the
 specs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1319#comment:28>
