[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with ApplyRasterConstraints and expand # of constraints on raster columns
trac at osgeo.org
Wed Nov 30 07:38:48 PST 2011
raster columns
Reporter: robe | Owner: dustymugs
Type: task | Status: assigned
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by mloskot):
Replying to [comment:28 pracine]:
> Replying to [comment:26 mloskot]:
> > Replying to [comment:22 dustymugs]:
> > > I believe the column "regular_blocking" should be renamed to
"same_alignment"
> > > as it is an analog to ST_SameAlignment.
> > AFAICT from the current docs on ST_SameAlignment, the regular_blocking
is
> > not the same concept.
> > The regular_blocking flag indicates if tiles in a table/coverage form
a
> > regular rectangular grid, or not.
> samealignment is necessary but not sufficient. Regularlyblocked also
needs
> samewidth, sameheight, hasnogaps and hasnooverlaps.
Indeed, ST_SameAlignment can not be used as replacement for the
regular_blocking flag.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1319#comment:30>
