[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with ApplyRasterConstraints and expand # of constraints on raster columns
PostGIS trac at osgeo.org
Wed Nov 30 09:57:39 PST 2011
raster columns
 Reporter:  robe            |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 Replying to [comment:27 mloskot]:
 > Replying to [comment:23 dustymugs]:
 > > Instead of having the column "out_db", the column should be renamed to
 "all_in_db"
 > Is it possible to have a raster partially "in_db" and partially
 "out_db". If it is not possible, "all_" prefix is superfluous.
 Yes.  Part of the problem is that out-of-db support is insufficient for
 actual use and needs a lot of work to make it usable.  But that won't
 happen until some time after 2.0.  Hence, I'm for getting rid of the
 out_db column.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1319#comment:34>
