[postgis-devel] [PostGIS] #1336: [raster] Problem with ST_AsRaster() alignment
trac at osgeo.org
Wed Nov 30 11:24:04 PST 2011
Reporter: pracine | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by dustymugs):
If you check the individual metadata of each raster, you'll see that the
Y-scale values differ. 1 vs -1. I'll add a check to ST_SameAlignment to
compare the absolute values for scale as there is no difference between 1
and -1 in terms of scale, just direction.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1336#comment:3>
