[postgis-devel] [PostGIS] #1336: [raster] Problem with ST_AsRaster() alignment
trac at osgeo.org
Wed Nov 30 11:58:38 PST 2011
Reporter: pracine | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by bnordgren):
Checking consistency of alignment may well be something that the
"physically relevant geotransform" code/algorithm could handle #1331 .
(pixel sizes are always positive). You just need to make a determination
as to whether "same alignment" includes the case where the j basis vectors
are opposed by 180 degrees. For instance, is it more important to you that
the transform be very simple like a shift and add, or is it just necessary
to have the grid cells be co-located?
In addition, it also becomes easier to circumscribe (''not'' inscribe)
gdal's suggested extent with a raster definition if the physically
significant parameters are available. Circumscribing an extent (GBOX) with
the grid definition of a source raster is exactly what motivated #1331. I
have an algorithm to circumscribe a gbox with a raster worked out on
paper.
This is actually the last known loose end for raster iterator.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1336#comment:6>
