[postgis-devel] [PostGIS] #1337: documentation: attribute-based restrictions reduce number of records, not fields returned
PostGIS trac at osgeo.org
Wed Nov 30 12:38:59 PST 2011
fields returned
 Reporter:  lorin          |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  low            |   Milestone:  PostGIS 1.5.4
Component:  documentation  |     Version:  1.5.X
 Keywords:                 |
Comment(by darkblueb):
 SQL theory says that you can restrict a SELECT operation by either row,
 column or both
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1337#comment:1>
