[postgis-devel] [PostGIS] #1213: [raster] RT_Intersects test fails
trac at osgeo.org
Sun Oct 2 11:31:55 PDT 2011
Reporter: strk | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by strk):
Returns true, as expected.
Note that the same PostGIS revision, with the same GDAL revision, passes
regress testing on my 64bit machine. The problem reported in my last
comment happens on a 32bit host:
PostgreSQL 8.4.8 on i486-pc-linux-gnu, compiled by GCC gcc-4.4.real
(Ubuntu 4.4
.3-4ubuntu5) 4.4.3, 32-bit
Postgis 2.0.0SVN - 2011-10-02 11:47:45
GEOS: 3.3.0-CAPI-1.7.0
PROJ: Rel. 4.7.1, 23 September 2009
Too bad there's no GDAL version in that header (see #1225)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1213#comment:14>
