[postgis-devel] [PostGIS] #286: Change "no SRID" SRID to 0
trac at osgeo.org
Mon Oct 3 08:18:20 PDT 2011
Reporter: pramsey | Owner: pramsey
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
Knon breakages so far seem to be all due to a mix of explicit and implicit
unknown srid.
One is in our testsuite (topology) and another I got a report for is in
qgis.
If we threat all SRID<=0 all the same way there should be much less
problems.
To me it's fine to map all to -1 for backward compatibility, to 0 for
sql/mm compatibility,
to NULL for strk-mind-compatibility.
But we do need to threat them all the same, IMHO (translate in input to a
common srid).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/286#comment:2>
