[postgis-devel] [PostGIS] #1213: [raster] RT_Intersects test fails
trac at osgeo.org
Tue Oct 4 12:53:07 PDT 2011
Reporter: strk | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by dustymugs):
Can you try r7941? After discussing with Frank
(http://trac.osgeo.org/gdal/ticket/4274), I've made a slight change that
affects the extent of the raster created from a geometry.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1213#comment:19>
