[postgis-devel] [PostGIS] #1230: _ST_BestSRID should not return negative SRID values
trac at osgeo.org
Fri Oct 7 10:38:32 PDT 2011
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
Is it normal that the current _st_bestSRID returns -32601 for POINT(-180
0) and -32661 for POINT(180 0) ? That is basically computing from zone=1
to zone=61 ! It'd be worth preparing a proper test for the current
behavior.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1230#comment:10>
