[postgis-devel] [PostGIS] #1238: [raster] Resample and upperleftx , upperlefty
trac at osgeo.org
Tue Oct 11 07:59:29 PDT 2011
Reporter: standa | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: ST_Resample |
Comment(by dustymugs):
I'm pretty sure that you have the correct version. But, I can't tell
which Windows package you are using. You should be using
http://www.postgis.org/download/windows/pg90/experimental/postgis/postgis-
pg90-binaries-2.0.0svn.zip
My guess is that GDAL isn't able to find the PROJ library since the upper-
left corner isn't changing. You may want to try setting the environmental
variable PROJSO and see if that helps.
http://trac.osgeo.org/gdal/wiki/ConfigOptions#PROJSO
Can you post your results from the SQL query I posted?
As I don't use Windows, I'm hoping Regina can chime in and offer some
wisdom.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1238#comment:5>
