[postgis-devel] [PostGIS] #1052: Tiger Geocoder 2010 Geocode() "squishing" toward end of block
trac at osgeo.org
Thu Oct 13 08:58:26 PDT 2011
Reporter: mikepease | Owner: robe
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment(by mikepease):
I tried to manually change rtoadd and ltoadd
in the tiger.edges and tiger_data.mn_edges tables
to the correct max addresses of 3252 and 3253
for gid=540165
to see if the geocoder would get a better result, but the result ended up
the same as before I changed those values.
Is there some other data I need to change for this to have an affect?
A cache or index or something? I'm confused that it didn't change the
result.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1052#comment:14>
