[postgis-devel] [PostGIS] #866: [raster] Change the ST_MapAlgebra nodatavalueexpr text parameter for nodatavaluerepl
trac at osgeo.org
Tue Oct 18 07:37:42 PDT 2011
nodatavaluerepl
Reporter: pracine | Owner: dzwarg
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by pracine):
More explanations:
-nodatavalueexpr would be an expression possibly containing "rast".
-nodatavaluerepl is not an expression, it is a constant replacement value
of type double.
After analysis (done with David in Mtl) we concluded that it makes no
sense to pass a nodata value expression (nodatavalueexpr) of "rast" since
in this case "rast" is always "nodata" and hence a constant. So it is
better, simpler and makes more sense to just pass a constant "nodata value
replacement" (nodatavaluerepl).
Everything would work with nodatavalueexpr. But it makes more sense to
pass a constant. It is also a bit faster as it does not have to be
evaluated.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/866#comment:6>
