[postgis-devel] [PostGIS] #590: [raster] Two rasters version of ST_MapAlgebra
PostGIS trac at osgeo.org
Fri Oct 21 07:40:09 PDT 2011
 Reporter:  pracine         |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by pracine):
 Replying to [comment:10 dustymugs]:
 > I don't know if it is appropriate for ST_MapAlgebra to do the alignment
 automatically as the behavior would differ from the behavior of other
 exceptions, primarily different SRIDs.  Technically, you could reproject
 the second raster to that of the first automatically as well but we're
 outputting an exception instead.  Outputting an exception is in-line with
 the behavior found in the geometry functions.
 > In addition, the resampling of the second raster may change (probably
 will) depending on the resampling algorithm used, which I think is a
 decision that the end-user must make.
 I would tend to agree. Normally the same way every raster in a table
 should have the same SRID, they should also be aligned.
 > 2. For the resulting raster's extent...
 >      The computation extent (extentexpr in the functions below) and
 hence the extent of the resulting raster can be:
 >         -'FIRST' (the extent of the first raster) (default),
 >         -'SECOND' (the extent of the first raster),
 >         -'INTERSECTION' (the extent of the intersection of both rasters)
 (could also be default),
 >         -'UNION' (the extent of the union of both rasters).
 > I think the default should be INTERSECTION or UNION as they are the most
 obvious from the user's standpoint.  I'd prefer INTERSECTION as that is
 typically the most compact.
 I agree.
 > 3. For the expressions dealing with nodata...
 >     Alternative expressions, evaluated in place of the main expression,
 can be provided as parameter to deal with nodata values:
 >         -nodata1expr is evaluated when the first raster pixel value is
 nodata or when the first raster is absent from the pixel area being
 evaluated
 >         -nodata2expr is evaluated when the second raster pixel value is
 nodata or when the second raster is absent from the pixel area being
 evaluated
 >         -nodatanodataexpr is evaluated when both rasters pixel values
 are nodata or when the both rastera are absent from the pixel area being
 evaluated
 >         -expression is evaluated when both raster pixel values are
 withdata.
 >     All expressions default to NULL. When an expression is NULL every
 pixel filling the condition of this expression is set to NULL (nodata).
 > My concern is with the last sentence "When an expression is NULL every
 pixel filling the condition of this expression is set to NULL (nodata).".
 What is the nodata value in this situation when the pixel is set to NULL?
 It is the nodata value of the new raster which should be determined first
 by the following rule: 1) The nodata value of the first raster if it exist
 2) if not, the nodata value of the second raster if it exist 3) if not,
 the min possible value according to the type of the raster. We could also
 add a parameter to specify the nodata value of the new raster.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/590#comment:13>
