[postgis-devel] [PostGIS] #590: [raster] Two rasters version of ST_MapAlgebra
trac at osgeo.org
Mon Oct 24 07:14:52 PDT 2011
Reporter: pracine | Owner: dustymugs
Type: task | Status: assigned
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by dustymugs):
> The question we have to solve, since this is specific to raster, is
"Should we resample implicitely when needed?" This is also the first time
we are facing the issue since this is the first function involving two
rasters (the question should have raised for ST_Intersects(raster, raster)
however. Bborie, does that mean that it is possible for two rasters being
resampled differently to return a different result for ST_Intersects()?).
For sure there should be a warning if implicit resampling is performed.
For the ST_Intersects() function, the alignment of the two rasters do not
matter. Only the SRID must be the same. This is because ST_Intersects
uses the grid/pixel lines and sees where they intersect. So being aligned
and resampling is unnecessary.
As for your question "does that mean that it is possible for two rasters
being resampled differently to return a different result for
ST_Intersects()?", no. Whatever resampling is done, the output resampled
raster's extent would contain the entirety of the input raster.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/590#comment:17>
