[postgis-devel] [PostGIS] #701: Support for 9.1 KNN GIST	enhancements
    trac at osgeo.org
    Tue Oct 25 08:31:21 PDT 2011
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by robe):
 Paul -- I think this one is done -- no?  Close it out if it is.
 Markstos,
 We already have this in the PostGIS 2.0 code base planned release around
 February 2011. You can try it out now to see if it fits your needs.
 You may want to take a look at Vizzuality video to see how this comes into
 play with what they are doing. http://vimeo.com/30158794
 Not sure it will work for you offhand unless your searches are a user
 input point.
 It doesn't look like your query is written that way but that may be more
 to do with compromises using what you had.  Note the limitation is that
 one of the geometries has to be a constant.
 As far as stuff needing peer review.  The other GIST enhancement slated
 for 9.2 release is what we badly need review help/and or funding on.
 http://www.postgresonline.com/journal/archives/225-Improving-speed-of-
 GIST-indexes-in-PostgreSQL-9.2.html
Ticket URL: <http://trac.osgeo.org/postgis/ticket/701#comment:8>
