[postgis-devel] [PostGIS] #1252: SRID appearing in ST_AsText for particular multipolygon
trac at osgeo.org
Fri Oct 28 01:13:17 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by robe):
Yes indeed: ST_AsEWKT of
SELECT ST_AsEWKT(ST_Union(geom))
FROM (SELECT (ST_Dump(geom)).geom
FROM weird_mpoly) As foo ;
SRID=4326;MULTIPOLYGON(SRID=4326;((-116.9937666 33.4711291,-116.9936485
33.4698868,-116.992874 33.4689698,-116.9911977 33.4686095,-116.9889499
33.4689424,-116.9865345 33.4688388,-116.9849953 33.4684547,-116.9832575
33.4670819...
SELECT ST_AsEWKT(geom) from weird_mpoly;
returns
{{{ SRID=4326;MULTIPOLYGON(((-116.9937666 33.4711291,-116.9936485
33.4698868,-116.992874 33.4689698,-116.9911977 33.4686095...
I'm not sure why it does it with just this geometry though. dump/union is
something I do all the time and with even more complex sets and this has
never happened to my knowledge. I spot checked some of my others and they
look fine.
I fear this is something we introduced in 1.5.3, because like I said, I
don't seem to be able to replicate it on my 1.5.2 install but can on a
clean 1.5.3 install. Granted my 1.5.2 has gone thru many upgrades.
I'm not sure GEOS is the culprit or even Union since I am running GEOS
3.3.1 (wlel maybe GEOS 3.3.0 on my 1.5.2). I have to check.
I'm beginning to get suspicious of ST_Dump. I'll check if we made changes
to that in 1.5.3
strk -- are you able to replicate it on your end with a 1.5.3 the
weird_mpoly.sql I attached. It oculd be a windows only issue.
I don't see the behavior in 2.0, but it could be camouflaged by the the
changes we've made so may be lurking in a different form.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1252#comment:7>
