[postgis-devel] "make check" failure
David Zwarg
dzwarg+postgis at azavea.com
Fri Oct 28 08:20:51 PDT 2011
On Fri, Oct 28, 2011 at 11:13 AM, Bborie Park <dustymugs at gmail.com> wrote:
> On Fri, Oct 28, 2011 at 8:08 AM, David Zwarg <dzwarg+postgis at azavea.com>
> wrote:
> > Greetings,
> > I just did an update (r8025), and I am getting failures from "make check"
> > here:
> > Testing rt_raster_same_alignment
> > ERROR: rt_raster_same_alignment: The two raster provided have different
> > scales on the X axis
> > Check failed on line 2083
> > The last good revision that passes all the tests for me is r7995; r7997
> > fails 4 sql regression tests; r7998 fails 6 regresson tests; r7999 fails
> > with the above.
> > My system is:
> > PostgreSQL 9.0.4 on i686-pc-linux-gnu, compiled by GCC gcc (Ubuntu
> > 4.4.3-4ubuntu5) 4.4.3, 32-bit
> > Postgis 2.0.0SVN - 2011-10-01 10:32:22
> > GEOS: 3.2.2-CAPI-1.6.2
> > PROJ: Rel. 4.7.1, 23 September 2009
> > GDAL: GDAL 1.8.0, released 2011/01/12
> > My shell process for checking these builds is:
> > svn update -r 7995
> > ./autogen.sh
> > ./configure --with-pgconfig=/usr/local/pgsql/bin/pg_config
> > make
> > sudo make install
> > pg_ctl -D /usr/local/pgsql/data stop
> > pg_ctl -D /usr/local/pgsql/data start
> > cd raster
> > make check
> > cd ..
> > Am I doing something wacky here?
> > David
> Hey David,
> I usually run "make clean" after the ./configure. If I'm really
> paranoid, I'll run "make distclean before I do the svn update.
> -bborie
Still no go.
I did both "make distclean" before "svn update -r 8026", AND a "make clean"
after ./configure.
Please advise,
z
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20111028/250b14db/attachment.html>
