[postgis-devel] How define a view that use a case operator for geometry field
aperi2007
aperi2007 at gmail.com
Fri Oct 28 10:11:18 PDT 2011
Il 28/10/2011 18:51, Sandro Santilli ha scritto:
> On Fri, Oct 28, 2011 at 06:48:10PM +0200, aperi2007 wrote:
>> case
>> when a.codlinea<>'' then b.geom::geometry(LINESTRING,3003)
>> when a.codlineasoprasotto<>'' then c.geom::geometry(LINESTRING,3003)
>> end as geom
> ELSE ?
>> Is correct that geometry_columns don't report the geometry-type and
>> the srid of a view defined like this ?
> Try:
> SELECT * FROM the_view WHERE ST_SRID(geom) = 0;
I try
SELECT * FROM v_elemento_divisorio WHERE ST_SRID(geom) = 0;
the result was an empty recordset.
(very strange for me)
After this I change (following your suggest) the view with:
case
else c.geom::geometry(LINESTRING,3003)
end as geom
And it work ! (wow)
Now qgis-identify work correctly no error. :)
Try-ing again the
it return again an empty recordset.
why the first view don't give any error ?
