[postgis-devel] [PostGIS] #1259: xsl scripts to generate programmer cheat sheets
trac at osgeo.org
Mon Oct 31 04:18:44 PDT 2011
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
I usually create cheat sheets and post to BostonGIS.com for each version
of PostGIS which seem fairly popular. Given we have so much in PostGIS
2.0, I generated some xsl scripts to standardize it and make it easier to
generate and change.
I have this more or less done for topology and tiger geocoder.
Which you can run with on r8058
cd doc
make topology_cheatsheet.html
make tiger_geocoder_cheatsheet.html
For the raster and PostGIS ones I may need to leave out the descriptions
to make the function names fit on 3-4 pages. My ideal size is like a 2-3
pager for everything.
I'm thinking of having some way to designate what listings get included in
cheat sheets as well - like a new tag or something as some functions are
more common place than others. Right now I'm just outputting the first
program listing from each function, which is still a lot even for
topology.
any other thoughts are welcome.
Attached are the current generated tiger and topology versions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1259>
