[postgis-devel] [PostGIS] #1170: North Pole Intersection fails with "Coordinate values out of range"
PostGIS trac at osgeo.org
Thu Sep 1 13:57:12 PDT 2011
 Reporter:  jgilman   |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 1.5.4
Component:  postgis   |     Version:  1.5.X
 Keywords:            |
Comment(by bnordgren):
 Does it choose the "local planar projection" dynamically or is the
 projection fixed? What are the properties of the selected projection near
 the poles?
 It may be that there is no single projection which will work for
 intersecting with all geographies.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1170#comment:3>
