[postgis-devel] [PostGIS] #343: History Table Enhancements
trac at osgeo.org
Sun Sep 4 16:02:59 PDT 2011
Reporter: pimpaa | Owner: pimpaa
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: History Tables |
Comment(by pimpaa):
Hello guys,
I've discovered a huge problem with the rule system that it may invalidate
this current implementation in favor of triggers.
Here is the outline:
imagine this:
CREATE TABLE test(
id serial not null primary key);
SELECT * FROM ADDGEOMETRYCOLUMN('public','test','the_geom',-1,'POINT'2);
SELECT * FROM POSTGIS_CREATE_HISTORY('public','test','the_geom');
insert into test values (1,ST_GEOMFROMTEXT('POINT(1 1)'));
Our rule system works out beautiful in this scenario, because we are
passing a known value to our id. The rules will write everything correctly
to the database.
but imagine this insert
insert into test values(DEFAULT,ST_GEOMFROMTEXT('POINT(1 1)'));
In this case the value passed to the rules is nextval, therefore, leaping
an id, breaking the system (the logged id for this record is 2, instead of
1);
I think we should move on to triggers, since as I know it, there is no way
to workaround this rule behavior.
This is not a critical module, but I'm asking for your opinion guys and
gals.
I prefer to not have this functionality for one month or two while I
rewrite this module with triggers than showcase something that is half-
broken.
Thoughts?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/343#comment:17>
