[postgis-devel] [PostGIS] #1181: topology.TopologySummary is broken
PostGIS trac at osgeo.org
Fri Sep 9 04:50:16 PDT 2011
  Reporter:  robe      |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  trunk
Resolution:  fixed     |    Keywords:
Comment(by robe):
 Well stats.  I got it loaded with this command
 SELECT tiger.topology_load_tiger('topo_boston', 'place', '2507000');
 and summary for my clipped region returns
 Topology topo_boston (6), SRID 2249, precision 1
 19894 nodes, 30449 edges, 11109 faces, 0 topogeoms in 0 layers
 ran ValidateTopology and got 484 errors.  I suspect my left right edge
 logic is wrong because that was the only part not directly available in
 tiger edges structure. Also was trying to avoid having to bring the whole
 thing in so just set the left_ ... to - of the current edge where I
 clipped the topology.
 Scary -- will have to investigate where I went wrong or if its a flaw in
 tiger data.
 Some edges were really multilinestrings for one so don't fit in linestring
 restricted edge model we have.  I also assume we are not taking into
 consideration the tolerance yet so some might be stupid rounding errors
 since as Leo noted some nodes in tiger data that claim to be the same are
 slightly different.
 edge crosses edge;85695808;85695811
 edge crosses edge;85696752;85723278
 edge crosses edge;85696942;85727753
 edge crosses edge;85696943;85697487
 edge crosses edge;85697284;608979919
 edge crosses edge;85697537;85720011
 edge crosses edge;85697565;85728034
 edge crosses edge;85697565;634869800
 edge crosses edge;85698971;85698973
 edge crosses edge;85699835;85699836
 edge crosses edge;85701496;85701508
 edge crosses edge;85701858;85701866
 edge crosses edge;85702123;85702124
 edge crosses edge;85702130;85702137
 edge crosses edge;85703528;85735045
 edge crosses edge;85705725;85705726
 edge crosses edge;85705774;85705778
 edge crosses edge;85709730;85709731
 edge crosses edge;85710150;85717526
 edge crosses edge;85711232;85711348
 edge crosses edge;85712407;635346015
 edge crosses edge;85714383;85738889
 edge crosses edge;85715529;85715540
 edge crosses edge;85715539;85726410
 edge crosses edge;85717140;85717141
 edge crosses edge;85720254;85728172
 edge crosses edge;85721292;85724170
 edge crosses edge;85724590;612867218
 edge crosses edge;85725069;87127392
 edge crosses edge;85725854;85740032
 edge crosses edge;85726772;85731250
 edge crosses edge;85726993;85735538
 edge crosses edge;85728950;85736318
 edge crosses edge;85729124;85736365
 edge crosses edge;85730252;85736516
 edge crosses edge;85730337;613367291
 edge crosses edge;85730443;633317065
 edge crosses edge;85731427;85740038
 edge crosses edge;85732492;85741808
 edge crosses edge;85735634;85738066
 edge crosses edge;85737844;85738898
 edge crosses edge;85738677;85741619
 edge crosses edge;85739088;85740434
 edge crosses edge;631741617;631741619
 edge crosses edge;85695087;85722281
 edge crosses edge;85695810;85695818
 edge crosses edge;85696515;85696532
 edge crosses edge;85696621;85727524
 edge crosses edge;85698973;613369831
 edge crosses edge;85699648;85718350
 edge crosses edge;85701508;633012752
 edge crosses edge;85703839;85735329
 edge crosses edge;85704328;85729179
 edge crosses edge;85710752;85710757
 edge crosses edge;85714384;85738889
 edge crosses edge;85720331;624424009
 edge crosses edge;85724003;85724754
 edge crosses edge;85724874;85726920
 edge crosses edge;85725751;85729053
 edge crosses edge;85727043;85727045
 edge crosses edge;85728949;85736319
 edge crosses edge;85730130;85735780
 edge crosses edge;85730565;85739433
 edge crosses edge;85738144;618744419
 edge crosses edge;85739678;618752688
 edge crosses edge;85695240;85695246
 edge crosses edge;85701507;85724455
 edge crosses edge;85701546;85701571
 edge crosses edge;85705789;85705796
 edge crosses edge;85711231;85711232
 edge crosses edge;85720338;85720341
 edge crosses edge;85724203;85724204
 edge crosses edge;85724879;85734340
 edge crosses edge;85726349;85736034
 edge crosses edge;85726350;85736028
 edge crosses edge;85728468;85734999
 edge crosses edge;85728522;630520049
 edge crosses edge;85731554;613368912
 edge crosses edge;85731723;85739367
 edge crosses edge;85733494;85738647
 edge crosses edge;85738258;85739094
 edge crosses edge;85738272;85739118
 edge crosses edge;85740434;85740436
 edge crosses edge;85740435;85740534
 edge crosses edge;85741113;85741185
 edge crosses edge;85695646;85695812
 edge crosses edge;85697267;85697284
 edge crosses edge;85698487;85698490
 edge crosses edge;85699972;85699984
 edge crosses edge;85700763;85700772
 edge crosses edge;85701180;85701287
 edge crosses edge;85701931;85701933
 edge crosses edge;85703834;85703838
 edge crosses edge;85704135;85729112
 edge crosses edge;85711349;85711351
 edge crosses edge;85711349;85720047
 edge crosses edge;85711850;85741780
 edge crosses edge;85714385;618752688
 edge crosses edge;85722640;635115101
 edge crosses edge;85724167;85724170
 edge crosses edge;85724881;87108047
 edge crosses edge;85726745;85732549
 edge crosses edge;85728011;85728034
 edge crosses edge;85728011;634869800
 edge crosses edge;85730121;85730131
 edge crosses edge;85730129;85735781
 edge crosses edge;85731949;85737081
 edge crosses edge;85733521;85741619
 edge crosses edge;85736233;85738509
 edge crosses edge;85737969;618740625
 edge crosses edge;85737976;618744422
 edge crosses edge;85739033;85739034
 edge crosses edge;85740365;85740415
 edge start node geometry mis-match;85695126;81043829
 edge start node geometry mis-match;85697284;81045293
 edge start node geometry mis-match;85697822;81045664
 edge start node geometry mis-match;85698131;81045849
 edge start node geometry mis-match;85699865;81047037
 edge start node geometry mis-match;85701128;81047583
 edge start node geometry mis-match;85701288;81047925
 edge start node geometry mis-match;85701570;81048188
 edge start node geometry mis-match;85702061;81048515
 edge start node geometry mis-match;85702123;81048561
 edge start node geometry mis-match;85704129;81049907
 edge start node geometry mis-match;85705725;81050973
 edge start node geometry mis-match;85705774;81051012
 edge start node geometry mis-match;85705859;81050993
 edge start node geometry mis-match;85709065;81053207
 edge start node geometry mis-match;85710749;81054288
 edge start node geometry mis-match;85712407;81055326
 edge start node geometry mis-match;85713266;81055869
 edge start node geometry mis-match;85715529;81057337
 edge start node geometry mis-match;85721989;81048426
 edge start node geometry mis-match;85722851;81053599
 edge start node geometry mis-match;85723043;81045141
 edge start node geometry mis-match;85725068;81058937
 edge start node geometry mis-match;85725583;81046095
 edge start node geometry mis-match;85725854;81059767
 edge start node geometry mis-match;85728950;81060978
 edge start node geometry mis-match;85729053;81049496
 edge start node geometry mis-match;85729124;81061052
 edge start node geometry mis-match;85729179;81050053
 edge start node geometry mis-match;85730568;81061702
 edge start node geometry mis-match;85731314;81062048
 edge start node geometry mis-match;85732845;81062708
 edge start node geometry mis-match;85734419;81046081
 edge start node geometry mis-match;85735624;81055047
 edge start node geometry mis-match;85735780;81061502
 edge start node geometry mis-match;85738066;81063862
 edge start node geometry mis-match;85738290;81064151
 edge start node geometry mis-match;85738325;81064183
 edge start node geometry mis-match;85739088;81065128
 edge start node geometry mis-match;85739193;81065198
 edge start node geometry mis-match;85739400;81061999
 edge start node geometry mis-match;85740266;81061854
 edge start node geometry mis-match;85740981;81065734
 edge start node geometry mis-match;85741756;81063806
 edge start node geometry mis-match;85742397;81062097
 edge start node geometry mis-match;613368912;81057477
 edge start node geometry mis-match;618740625;81063718
 edge start node geometry mis-match;618752688;81052885
 edge start node geometry mis-match;624007766;81047153
 edge start node geometry mis-match;625298336;81061148
 edge start node geometry mis-match;630520384;81062018
 edge start node geometry mis-match;631741618;421382413
 edge start node geometry mis-match;633012950;81063434
 edge start node geometry mis-match;85694292;81043233
 edge start node geometry mis-match;85695087;81043812
 edge start node geometry mis-match;85695449;81044062
 edge start node geometry mis-match;85695481;81044062
 edge start node geometry mis-match;85695810;81044203
 edge start node geometry mis-match;85695811;81044298
 edge start node geometry mis-match;85698504;81046081
 edge start node geometry mis-match;85699648;81046897
 edge start node geometry mis-match;85700372;81047379
 edge start node geometry mis-match;85702060;81048515
 edge start node geometry mis-match;85702067;81048514
 edge start node geometry mis-match;85702137;81048565
 edge start node geometry mis-match;85702649;81048909
 edge start node geometry mis-match;85703839;81049708
 edge start node geometry mis-match;85709064;81053207
 edge start node geometry mis-match;85711076;81054488
 edge start node geometry mis-match;85715470;81057303
 edge start node geometry mis-match;85720331;81045910
 edge start node geometry mis-match;85720341;81047452
 edge start node geometry mis-match;85720506;81057672
 edge start node geometry mis-match;85723278;81044944
 edge start node geometry mis-match;85723281;81044949
 edge start node geometry mis-match;85724702;81054487
 edge start node geometry mis-match;85727010;81059369
 edge start node geometry mis-match;85727043;81043889
 edge start node geometry mis-match;85727067;81043916
 edge start node geometry mis-match;85729059;81049555
 edge start node geometry mis-match;85729471;81051101
 edge start node geometry mis-match;85731204;81061999
 edge start node geometry mis-match;85731538;81062145
 edge start node geometry mis-match;85735622;81062048
 edge start node geometry mis-match;85737281;81060570
 edge start node geometry mis-match;85739433;81061701
 edge start node geometry mis-match;85740200;81065369
 edge start node geometry mis-match;612867218;81047653
 edge start node geometry mis-match;613367291;81061598
 edge start node geometry mis-match;85696532;81044777
 edge start node geometry mis-match;85697269;81045295
 edge start node geometry mis-match;85698970;81046418
 edge start node geometry mis-match;85699984;81047097
 edge start node geometry mis-match;85700577;81047350
 edge start node geometry mis-match;85701546;81048173
 edge start node geometry mis-match;85702066;81048514
 edge start node geometry mis-match;85702264;81048647
 edge start node geometry mis-match;85703137;81049214
 edge start node geometry mis-match;85704284;81050020
 edge start node geometry mis-match;85715384;81056104
 edge start node geometry mis-match;85724203;81046432
 edge start node geometry mis-match;85724879;81058940
 edge start node geometry mis-match;85728522;81060777
 edge start node geometry mis-match;85728904;81060958
 edge start node geometry mis-match;85732478;81062562
 edge start node geometry mis-match;85734022;81063229
 edge start node geometry mis-match;85735258;81061020
 edge start node geometry mis-match;85736266;81062455
 edge start node geometry mis-match;85737829;81064475
 edge start node geometry mis-match;85738258;81064798
 edge start node geometry mis-match;85738272;81064806
 edge start node geometry mis-match;85741106;81065728
 edge start node geometry mis-match;85742297;81062226
 edge start node geometry mis-match;613367157;81059590
 edge start node geometry mis-match;613367266;81060570
 edge start node geometry mis-match;613370813;81062488
 edge start node geometry mis-match;631741632;421382413
 edge start node geometry mis-match;85695116;81043829
 edge start node geometry mis-match;85695646;81044084
 edge start node geometry mis-match;85695649;81044197
 edge start node geometry mis-match;85698487;81046093
 edge start node geometry mis-match;85704135;81049907
 edge start node geometry mis-match;85705724;81050973
 edge start node geometry mis-match;85711349;81054592
 edge start node geometry mis-match;85712254;81055207
 edge start node geometry mis-match;85713267;81055869
 edge start node geometry mis-match;85714026;81056389
 edge start node geometry mis-match;85721237;81058706
 edge start node geometry mis-match;85721250;81049907
 edge start node geometry mis-match;85722640;81055208
 edge start node geometry mis-match;85726745;81056455
 edge start node geometry mis-match;85727184;81059272
 edge start node geometry mis-match;85727641;81059590
 edge start node geometry mis-match;85730121;81053157
 edge start node geometry mis-match;85731724;81062226
 edge start node geometry mis-match;85732234;81062455
 edge start node geometry mis-match;85734999;81060750
 edge start node geometry mis-match;85735050;81061005
 edge start node geometry mis-match;85735538;81059087
 edge start node geometry mis-match;85736319;81060978
 edge start node geometry mis-match;85737557;81063806
 edge start node geometry mis-match;85737976;81064384
 edge start node geometry mis-match;85738136;81064718
 edge start node geometry mis-match;85738138;81064718
 edge start node geometry mis-match;85738648;81063211
 edge start node geometry mis-match;85739033;81065091
 edge start node geometry mis-match;609020740;81054487
 edge start node geometry mis-match;613367909;81054327
 edge start node geometry mis-match;633012840;81060699
 edge start node geometry mis-match;633012692;81048515
 edge start node geometry mis-match;85741619;81056606
 edge start node geometry mis-match;87318464;64728602
 edge start node geometry mis-match;87327504;64716202
 edge end node geometry mis-match;85695207;81043889
 edge end node geometry mis-match;85696942;81045064
 edge end node geometry mis-match;85697537;81045473
 edge end node geometry mis-match;85698115;81045844
 edge end node geometry mis-match;85700327;81047350
 edge end node geometry mis-match;85700373;81047379
 edge end node geometry mis-match;85700772;81047653
 edge end node geometry mis-match;85701287;81047925
 edge end node geometry mis-match;85701496;81048143
 edge end node geometry mis-match;85701545;81048173
 edge end node geometry mis-match;85701858;81048379
 edge end node geometry mis-match;85701933;81048426
 edge end node geometry mis-match;85702291;81048665
 edge end node geometry mis-match;85703125;81049223
 edge end node geometry mis-match;85703355;64690758
 edge end node geometry mis-match;85703528;81049496
 edge end node geometry mis-match;85704963;81050442
 edge end node geometry mis-match;85705426;81050744
 edge end node geometry mis-match;85705713;81050973
 edge end node geometry mis-match;85709332;81053371
 edge end node geometry mis-match;85709730;81053629
 edge end node geometry mis-match;85713204;81055829
 edge end node geometry mis-match;85715469;81057303
 edge end node geometry mis-match;85715858;81057583
 edge end node geometry mis-match;85718442;81044306
 edge end node geometry mis-match;85720254;81045664
 edge end node geometry mis-match;85720510;81057681
 edge end node geometry mis-match;85721236;81058706
 edge end node geometry mis-match;85721292;81049107
 edge end node geometry mis-match;85722701;81048971
 edge end node geometry mis-match;85726772;81056455
 edge end node geometry mis-match;85726920;81043329
 edge end node geometry mis-match;85727624;81044944
 edge end node geometry mis-match;85728111;81060578
 edge end node geometry mis-match;85728521;81060777
 edge end node geometry mis-match;85729474;81051101
 edge end node geometry mis-match;85731427;81062092
 edge end node geometry mis-match;85731544;81043233
 edge end node geometry mis-match;85732319;81062488
 edge end node geometry mis-match;85732477;81062562
 edge end node geometry mis-match;85733411;81062977
 edge end node geometry mis-match;85734339;81058937
 edge end node geometry mis-match;85734419;81060699
 edge end node geometry mis-match;85736028;81059993
 edge end node geometry mis-match;85736175;81064151
 edge end node geometry mis-match;85736516;81061558
 edge end node geometry mis-match;85738647;81063018
 edge end node geometry mis-match;85739157;81064828
 edge end node geometry mis-match;85739367;81062226
 edge end node geometry mis-match;85740415;81065117
 edge end node geometry mis-match;85741780;81054969
 edge end node geometry mis-match;85741808;81062567
 edge end node geometry mis-match;87324609;64716202
 edge end node geometry mis-match;630520506;419525479
 edge end node geometry mis-match;85695247;81043916
 edge end node geometry mis-match;85697022;81045106
 edge end node geometry mis-match;85698973;81046419
 edge end node geometry mis-match;85699107;81046513
 edge end node geometry mis-match;85700774;81047655
 edge end node geometry mis-match;85701566;81048188
 edge end node geometry mis-match;85703838;81049708
 edge end node geometry mis-match;85710757;81054288
 edge end node geometry mis-match;85710809;81054327
 edge end node geometry mis-match;85711076;81054487
 edge end node geometry mis-match;85711348;81054592
 edge end node geometry mis-match;85720337;81047452
 edge end node geometry mis-match;85724003;81058399
 edge end node geometry mis-match;85726269;81059955
 edge end node geometry mis-match;85727122;81044062
 edge end node geometry mis-match;85727209;81059303
 edge end node geometry mis-match;85733981;81063211
 edge end node geometry mis-match;85735981;81063229
 edge end node geometry mis-match;85737281;81063882
 edge end node geometry mis-match;85738144;81064384
 edge end node geometry mis-match;85738679;81063030
 edge end node geometry mis-match;85739317;81059999
 edge end node geometry mis-match;85739383;81059767
 edge end node geometry mis-match;85740436;81065128
 edge end node geometry mis-match;85741667;81045013
 edge end node geometry mis-match;85742022;81061994
 edge end node geometry mis-match;85742399;81062097
 edge end node geometry mis-match;85697487;81045064
 edge end node geometry mis-match;85699836;81047017
 edge end node geometry mis-match;85700662;81047583
 edge end node geometry mis-match;85701507;81048143
 edge end node geometry mis-match;85704190;81049952
 edge end node geometry mis-match;85705789;81051021
 edge end node geometry mis-match;85711231;81054590
 edge end node geometry mis-match;85716504;81057868
 edge end node geometry mis-match;85716978;81048647
 edge end node geometry mis-match;85717141;81058088
 edge end node geometry mis-match;85717526;81053915
 edge end node geometry mis-match;85718867;81053538
 edge end node geometry mis-match;85724202;81046432
 edge end node geometry mis-match;85726410;81057337
 edge end node geometry mis-match;85727524;81044716
 edge end node geometry mis-match;85727712;81045013
 edge end node geometry mis-match;85728034;81045473
 edge end node geometry mis-match;85729168;81050020
 edge end node geometry mis-match;85729404;64691256
 edge end node geometry mis-match;85732491;81062567
 edge end node geometry mis-match;85734520;81063400
 edge end node geometry mis-match;85735332;81062977
 edge end node geometry mis-match;85735909;81059407
 edge end node geometry mis-match;85737695;81060570
 edge end node geometry mis-match;85738080;81063882
 edge end node geometry mis-match;85738889;81052885
 edge end node geometry mis-match;85738898;81064563
 edge end node geometry mis-match;85739093;81064798
 edge end node geometry mis-match;85739120;81064806
 edge end node geometry mis-match;85740534;81065128
 edge end node geometry mis-match;85741113;81065799
 edge end node geometry mis-match;85742215;81045653
 edge end node geometry mis-match;87127392;81058940
 edge end node geometry mis-match;631741619;421382413
 edge end node geometry mis-match;630520503;81062097
 edge end node geometry mis-match;632936158;64716202
 edge end node geometry mis-match;633012752;81048143
 edge end node geometry mis-match;87294738;64689930
 edge end node geometry mis-match;85695246;81043916
 edge end node geometry mis-match;85701567;81048188
 edge end node geometry mis-match;85702284;81048665
 edge end node geometry mis-match;85703128;81049223
 edge end node geometry mis-match;85705743;81050993
 edge end node geometry mis-match;85710750;81054288
 edge end node geometry mis-match;85711552;81054801
 edge end node geometry mis-match;85711976;81055047
 edge end node geometry mis-match;85720631;81051102
 edge end node geometry mis-match;85724167;81049107
 edge end node geometry mis-match;85724881;81043334
 edge end node geometry mis-match;85725469;81059588
 edge end node geometry mis-match;85730129;81061502
 edge end node geometry mis-match;85731949;81062329
 edge end node geometry mis-match;85733521;81063030
 edge end node geometry mis-match;85734563;81063412
 edge end node geometry mis-match;85736034;81059993
 edge end node geometry mis-match;85736233;81064183
 edge end node geometry mis-match;85737560;81061702
 edge end node geometry mis-match;85738067;81063862
 edge end node geometry mis-match;85738649;81063211
 edge end node geometry mis-match;85738876;81059999
 edge end node geometry mis-match;85739069;81064602
 edge end node geometry mis-match;85741256;81065880
 edge end node geometry mis-match;633317065;81061646
 edge end node geometry mis-match;634869800;81045473
 edge end node geometry mis-match;635513685;81054690
 face without edges;0;
 face within face;205862783;205862095
 face within face;205862799;205862095
 face within face;205865351;205862095
 face within face;205874035;205862095
 face overlaps face;205862471;227168671
 face within face;205862735;250903961
 face within face;250903028;250903961
 face within face;205862896;250903961
 face within face;205862789;250883064
 face within face;205862817;250903961
 face within face;205862819;250883064
 face within face;205862823;250903961
 face within face;205862881;257319799
 face within face;257319799;205862881
 face within face;205862882;250903961
 face within face;205862887;250903961
 face overlaps face;205863302;257413188
 face overlaps face;205863376;229835545
 face overlaps face;205864246;250883108
 face overlaps face;205864660;227167582
 face within face;205864956;250883064
 face within face;205864957;250883064
 face within face;205865321;250903961
 face within face;205865345;227169008
 face within face;227169008;205865345
 face within face;205865352;205873116
 face within face;205873116;205865352
 face within face;205865363;205872319
 face within face;205872319;205865363
 face within face;205865373;205871833
 face within face;205871833;205865373
 face within face;205865395;205868775
 face within face;205868775;205865395
 face within face;205865958;250883064
 face overlaps face;205866227;257444605
 face overlaps face;205867277;229835545
 face overlaps face;205867238;229835545
 face overlaps face;205868159;258319348
 face within face;205869028;250903961
 face within face;227168330;250883064
 face overlaps face;205869512;227168349
 face within face;205869559;250883064
 face within face;205869560;250883064
 face within face;205869563;250904452
 face overlaps face;205869736;250882878
 face overlaps face;205870367;258108715
 face overlaps face;205870367;258362605
 face within face;205870672;205872411
 face within face;205872411;205870672
 face overlaps face;205871034;227168389
 face overlaps face;205871127;227168774
 face overlaps face;205871321;258108715
 face overlaps face;205871321;258362605
 face overlaps face;205871462;226888629
 face overlaps face;205871550;227167502
 face overlaps face;205872480;257444534
 face overlaps face;205872480;257444535
 face within face;205872795;205872797
 face within face;205872797;205872795
 face within face;205873814;250882844
 face within face;250882844;205873814
 face within face;227168331;250883064
 face within face;250904453;250904452
 face within face;250903962;250903961
 face within face;250903029;250903961
 As far as speed -- it varied a lot on which box I was running it on (and
 was way faster on my 9.1 install compared to 9.0) so will have to revisit
 that.  Right now just focusing on correctness - making sure generated face
 geometries match original face geometries of tiger and so forth.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1181#comment:4>
