[postgis-devel] [PostGIS] #1181: topology.TopologySummary is broken
PostGIS trac at osgeo.org
Fri Sep 9 13:54:44 PDT 2011
  Reporter:  robe      |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  trunk
Resolution:  fixed     |    Keywords:
Comment(by aperi2007):
 Robe,
 I don't know your tiger dataset.
 You are using the topology ISO functions ?
 Or try to load directly in the tables ?
 If you use the ISO function you should not see happened that
 validatetopology error. The ISO function should directly lock any try to
 insert a wrong edge.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1181#comment:5>
