[postgis-devel] [PostGIS] #1176: [raster] Two raster ST_Intersects
PostGIS trac at osgeo.org
Fri Sep 9 21:12:00 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  enhancement     |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Changes (by dustymugs):
  * status:  new => assigned
Comment:
 A proposed set of two raster ST_Intersects functions.  All existing
 raster/geometry functions will stay the same, though they may be adjusted
 to decide if converting the geometry to a raster is better solution that
 converting the raster to a set of geometries.
 1. ST_Intersects(raster rastA, integer bandA, boolean
 exclude_nodata_valueA, raster rastB, integer bandB, boolean
 exclude_nodata_valueB) -> boolean
 2. ST_Intersects(raster rastA, integer bandA, raster rastB, integer bandB,
 ) -> boolean
 3. ST_Intersects(raster rastA, boolean exclude_nodata_valueA, raster
 rastB, boolean exclude_nodata_valueB) -> boolean
 4. ST_Intersects(raster rastA, raster rastB, integer bandA DEFAULT 1,
 boolean exclude_nodata_valueA DEFAULT TRUE, integer bandB DEFAULT 1,
 boolean exclude_nodata_valueB DEFAULT TRUE) -> boolean
 5. ST_Intersects(raster rastA, raster rastB, integer bandA, integer bandB)
 -> boolean
 6. ST_Intersects(raster rastA, raster rastB, boolean
 exclude_nodata_valueA, boolean exclude_nodata_valueB DEFAULT TRUE) ->
 boolean
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1176#comment:3>
