[postgis-devel] [raster] Implementations of rotation and pixel size.
Bborie Park
dustymugs at gmail.com
Sat Sep 10 13:26:04 PDT 2011
Hey David,
Sigh. Disregard my message about adding the hard limit of 90 degrees.
I realized after I sent the prior email that one of my equations was
incorrect.
-bborie
On Fri, Sep 9, 2011 at 9:01 PM, Bborie Park <dustymugs at gmail.com> wrote:
> Hey David,
> I was wondering if you could add the hard limit of 90 degrees for
> RASTER_setRotation. In writing what will become ST_Intersects(raster,
> raster), I was doing some testing on setting skew and what I realized
> is that as the numbers for skew (X and Y) get larger and larger, you
> get infinitely closer to plus/minus 90 degrees but will never there.
> As such, setting a limit saying that the rotation must be less than 90
> degrees sounds reasonable to me.
> -bborie
> On Thu, Aug 18, 2011 at 4:19 PM, dustymugs <dustymugs at gmail.com> wrote:
>> Hey David,
>> I've looked at the patch attached to #482 and find no issues with it.
>> Everything (merging, compilation, regression testing and checking for memory
>> leaks) looks good.
>> The only thing I changed with the patch remove the diff for GNUmakefile.in,
>> which is outside the raster directory.
>> I have no recommendation to setting a hard limit of 90 degrees for
>> RASTER_setRotation. It makes sense to me but I'd hope that Pierre chimes
>> in.
>> -bborie
>> On 08/18/2011 02:36 PM, David Zwarg wrote:
>>> Greetings raster devs,
>>> I took a day to implement the outstanding tickets that I had for some of
>>> the
>>> accessors related to rotated rasters:
>>> - #928 - Implement ST_PixelWidth
>>> <http://trac.osgeo.org/postgis/ticket/928>
>>> - #929 - Implement ST_PixelHeight
>>> <http://trac.osgeo.org/postgis/ticket/929>
>>> - #936 - Implement ST_Rotation
>>> <http://trac.osgeo.org/postgis/ticket/936>
>>> - #482 - Implement
>>> ST_SetRotation<http://trac.osgeo.org/postgis/ticket/482>
>>> If someone could take a moment to review the patches attached to those
>>> tickets, that would be helpful. One of the things that I did not do was to
>>> limit the rotation amount in ST_SetRotation. I was reading more on the
>>> world
>>> file, and it sounds like a raster shouldn't be rotated more than 90
>>> degrees
>>> -- should that be a hard limit in ST_Rotation? If the rotation exceeds 90
>>> degrees, does the affine transformation go haywire? In addition, the
>>> UpperLeft position should realistically be changed. Otherwise, you could
>>> technically define different rasters that cover the same area, but with
>>> different UpperLeft coordinates (imagine if the geotransform put the
>>> UpperLeft pixel at the lower right, and applied a 180 degree rotation).
>>> Thanks,
>>> David
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
