[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
trac at osgeo.org
Mon Sep 12 09:38:05 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
It's also interesting to note that on Linux I don't get postgresql library
in the link line, while you seem to be getting that (the
'-Lc:/projects/pg/pg84/lib -lpostgres' right after objects list).
Since that's being the problem I wonder if 9.0 fixed a bug in 8.4 pgxs
threatment, and how we can workaround that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:56>
