[postgis-devel] [PostGIS] #1165: performance degradation between 1.5.3 and 2.0.0SVN
trac at osgeo.org
Tue Sep 13 11:46:25 PDT 2011
Reporter: edoardopanfili | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by strk):
You may actually have found the culprit. Re-add that include and try it.
I'll be off for ~ 7 hours...
If confirmed we should move the PREPARED_GEOM define from that include to
a postgis_config.h or something like that (driven by configure) to reduce
future cases of this.
Beside, if this is confirmed it means prepared geoms will only be
available
in postgis, not in liblwgeom.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1165#comment:21>
