[postgis-devel] [PostGIS] #1176: [raster] Two raster ST_Intersects
trac at osgeo.org
Wed Sep 14 06:21:02 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by bnordgren):
Replying to [comment:12 pracine]:
> If I understand well these could be used to implement c version of all
the world2raster and raster2world plpgsql functions?
Yep. It's actually performed by GDAL using the GDALApplyGeoTransform()
function. GDAL is also used to calculate the inverse transform whenever
the accessors are used to change the parameters of the affine transform
(scale, skew, offset). In essence, the forward and reverse transforms are
always pre-computed and ready for use.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1176#comment:13>
