[postgis-devel] [PostGIS] #1194: geometry_column wrong to establish the geometrytype in some views
trac at osgeo.org
Wed Sep 14 15:03:14 PDT 2011
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Andrea,
Unfortunately I fear that is one of those gotchas which I'll be explaining
in the FOSS4G talk we are giving. When you apply a postgis function,
there is no way for PostgreSLQ to know the geometry output type since our
functions just return a goemetry.
The work around is to cast it.
Can you try that and see if it makes a difference?
on both
ST_Force_3D(b.geom)::geometry(POLYGONZ,yoursridhere)
Do that for both parts of your union all.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1194#comment:1>
