[postgis-devel] [PostGIS] #1196: topologysummary fails
trac at osgeo.org
Thu Sep 15 02:46:02 PDT 2011
Reporter: martinl | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Resolution: fixed | Keywords:
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:1 strk]:
> I tought robe fixed this at r7823. Are you sure you re-sourced
topology.sql after svn update && ./configure --with-topology && make ?
Right, after re-sourcing `topology.sql` it works. Thanks. Martin
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1196#comment:2>
