[postgis-devel] [PostGIS] #1045: TopologyException if I don't use ST_Dump to resolve single geometries before I do ST_Intersection
trac at osgeo.org
Fri Sep 16 02:26:42 PDT 2011
Reporter: laopsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: trunk
Keywords: TopologyException ST_intersection ST_Dump |
Changes (by dmiranda):
* version: 1.5.X => trunk
Comment:
I have a similar problem and I am getting the same error message when
using st_union:
ERROR: GEOSUnionCascaded: TopologyException: found non-noded
intersection between LINESTRING (-54.7158 -28.0099, -54.7156 -28.0116) and
LINESTRING (-54.7158 -28.0099, -54.7158 -28.0119) at -54.7158 -28.0099
SQL state: XX000
BUT I have yet to find a reliable test case. If I dump a small subset of
data, reload an try again, the task will complete just fine. The whole
dataset is bigger than the upload limit of 5MB (if I dump and reload the
entire dataset the message shows up again).
Ubuntu 11.04
Postgresql 9.1
postgis 2.0.0svn R7856 Last Changed Date: 2011-09-15 14:43:57
GEOS 3.4.0dev Rev: 3465 Last Changed Date: 2011-09-12 01:47:39
Does it have anything to do with #1173?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1045#comment:2>
