[postgis-devel] [PostGIS] #1197: Newlines in shapefiles not handled correctly by shp2pgsql
PostGIS trac at osgeo.org
Fri Sep 16 05:48:09 PDT 2011
 Reporter:  dmiranda           |       Owner:  mcayland
     Type:  defect             |      Status:  new
 Priority:  high               |   Milestone:  PostGIS 2.0.0
Component:  postgis            |     Version:  trunk
 Keywords:  newline shp2pgsql  |
Changes (by mcayland):
  * owner:  pramsey => mcayland
Comment:
 I'm afraid I can't reproduce this here as the following file works under
 plain PostgreSQL for me:
 postgres at zeno:~$ cat /tmp/mca.sql
 SET CLIENT_ENCODING TO UTF8;
 SET STANDARD_CONFORMING_STRINGS TO ON;
 BEGIN;
 CREATE TABLE "newline" (gid serial,
 "id" numeric(10,0),
 "content" varchar(80));
 ALTER TABLE "newline" ADD PRIMARY KEY (gid);
 INSERT INTO "newline" ("id","content") VALUES ('1','bla
 bla
 bla');
 COMMIT;
 postgres at zeno:~$ psql -d foo -f /tmp/mca.sql -U foo -h localhost
 Password for user foo:
 SET
 SET
 BEGIN
 psql:/tmp/mca.sql:6: NOTICE:  CREATE TABLE will create implicit sequence
 "newline_gid_seq" for serial column "newline.gid"
 CREATE TABLE
 psql:/tmp/mca.sql:7: NOTICE:  ALTER TABLE / ADD PRIMARY KEY will create
 implicit index "newline_pkey" for table "newline"
 ALTER TABLE
 INSERT 0 1
 COMMIT
 postgres at zeno:~$ psql -d foo -U foo -h localhost
 psql (8.4.8)
 SSL connection (cipher: DHE-RSA-AES256-SHA, bits: 256)
 Type "help" for help.
 foo=> select * from newline;
  gid | id | content
    1 |  1 | bla
           : bla
           : bla
 (1 row)
 The use of standard_conforming_strings should be enough so that multi-line
 INSERT statements are accepted correctly without having to escape anything
 other than as dictated by the SQL standard.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1197#comment:1>
