[postgis-devel] Problems compiling ( libtool )
Nathaniel Hunter Clay
clay.nathaniel at gmail.com
Sun Sep 18 23:34:09 PDT 2011
On 09/19/2011 01:45 AM, Sandro Santilli wrote:
> On Sun, Sep 18, 2011 at 08:09:50PM -0400, Nathaniel Hunter Clay wrote:
>> Hi all,
>> I am having trouble compiling postgis svn trunk on Ubuntu 11.10. I
>> have gcc installed, is there anything I need to do to inform libtool
>> where to point etc.?
>> Thanks,
>> Nathaniel H Clay
>> nathaniel at nathan-MS-7599:/srv/gis/postgis$ make
>> for s in liblwgeom libpgcommon regress postgis loader utils raster
>> topology; do \
>> echo "---- Making all in ${s}"; \
>> make -C ${s} all || exit 1; \
>> done;
>> ---- Making all in liblwgeom
>> make[1]: Entering directory `/srv/gis/postgis/liblwgeom'
>> /bin/sh ../libtool --mode=compile gcc -g -O2 -fPIC -DPIC -Wall
>> -Wmissing-prototypes -I/usr/include -DPOSTGIS_GEOS_VERSION=32
>> -DPOSTGIS_PROJ_VERSION=47 -c -o stringbuffer.lo stringbuffer.c
>> eval: 1: base_compile+= gcc: not found
>> eval: 1: base_compile+= -g: not found
>> eval: 1: base_compile+= -O2: not found
>> eval: 1: base_compile+= -fPIC: not found
>> eval: 1: base_compile+= -DPIC: not found
>> eval: 1: base_compile+= -Wall: not found
>> eval: 1: base_compile+= -Wmissing-prototypes: not found
>> eval: 1: base_compile+= -I/usr/include: not found
>> eval: 1: base_compile+= -DPOSTGIS_GEOS_VERSION=32: not found
>> eval: 1: base_compile+= -DPOSTGIS_PROJ_VERSION=47: not found
>> eval: 1: base_compile+= -c: not found
>> eval: 1: CC_quoted+= gcc: not found
>> libtool: compile: you must specify a compilation command
>> libtool: compile: Try `libtool --help --mode=compile' for more information.
>> make[1]: *** [stringbuffer.lo] Error 1
>> make[1]: Leaving directory `/srv/gis/postgis/liblwgeom'
>> make: *** [all] Error 1
>> nathaniel at nathan-MS-7599:/srv/gis/postgis$ gcc --help
>> Usage: gcc [options] file...
> Did you run ./autogen.sh&& ./configure recently ?
> What's the output of ./configure ?
> --strk;
> () Free GIS& Flash consultant/developer
> /\http://strk.keybit.net/services.html
Strk,
I ran ./autogen.sh and ./configure, just after updating the sources
with svn update before sending out the email. Bumping up a revision and
getting the same result. I decided to email the development list.
Here is the output of configure you requested, I hope this helps...:
nathaniel at nathan-MS-7599:/srv/gis/postgis$ ./configure --with-raster
--with-topology
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking how to print strings... printf
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to
x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking for gawk... no
checking for mawk... mawk
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports
shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking if g++ supports -Wall... yes
checking if g++ supports -Wmissing-prototypes... yes
checking if g++ supports -ffloat-store... yes
checking for flex... no
checking for lex... no
checking for bison... no
checking for byacc... no
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking for vasprintf... yes
checking for asprintf... yes
checking for convert... /usr/bin/convert
checking for xsltproc... no
configure: WARNING: xsltproc is not installed so documentation cannot be
built
checking for dblatex... no
configure: WARNING: dblatex is not installed so PDF documentation cannot
be built
configure: WARNING: could not locate Docbook stylesheets required to
build the documentation
checking CUnit/CUnit.h usability... no
checking CUnit/CUnit.h presence... no
checking for CUnit/CUnit.h... no
configure: WARNING: could not locate CUnit required for liblwgeom unit tests
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking for libiconv_open in -liconv... no
checking for iconv_open in -lc... yes
checking for iconvctl... no
checking for libiconvctl... no
checking for pg_config... /usr/bin/pg_config
checking PostgreSQL version... PostgreSQL 9.1.0
checking libpq-fe.h usability... yes
checking libpq-fe.h presence... yes
checking for libpq-fe.h... yes
checking for PQserverVersion in -lpq... yes
checking for xml2-config... /usr/bin/xml2-config
checking libxml/tree.h usability... yes
checking libxml/tree.h presence... yes
checking for libxml/tree.h... yes
checking libxml/parser.h usability... yes
checking libxml/parser.h presence... yes
checking for libxml/parser.h... yes
checking libxml/xpath.h usability... yes
checking libxml/xpath.h presence... yes
checking for libxml/xpath.h... yes
checking libxml/xpathInternals.h usability... yes
checking libxml/xpathInternals.h presence... yes
checking for libxml/xpathInternals.h... yes
checking for xmlInitParser in -lxml2... yes
checking for geos-config... /usr/bin/geos-config
checking GEOS version... 3.2.2
checking geos_c.h usability... yes
checking geos_c.h presence... yes
checking for geos_c.h... yes
checking for initGEOS in -lgeos_c... yes
checking whether make sets $(MAKE)... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking whether NLS is requested... yes
checking for msgfmt... no
checking for gmsgfmt... :
checking for xgettext... no
checking for msgmerge... no
checking for ld used by GCC... /usr/bin/ld -m elf_x86_64
checking for shared library run path origin... done
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking proj_api.h usability... yes
checking proj_api.h presence... yes
checking for proj_api.h... yes
checking for pj_get_release in -lproj... yes
TOPOLOGY: Topology support requested
RASTER: Raster support requested
checking for GDAL >= 1.6.0... found
checking for GDALFPolygonize in -lgdal... no
checking for GDAL Python bindings... found
checking for NumPy array support in GDAL Python bindings... found
configure: creating ./config.status
config.status: creating GNUmakefile
config.status: creating liblwgeom/Makefile
config.status: creating liblwgeom/cunit/Makefile
config.status: creating liblwgeom/liblwgeom.h
config.status: creating libpgcommon/Makefile
config.status: creating libpgcommon/cunit/Makefile
config.status: creating postgis/Makefile
config.status: creating postgis/sqldefines.h
config.status: creating loader/Makefile
config.status: creating loader/cunit/Makefile
config.status: creating topology/Makefile
config.status: creating regress/Makefile
config.status: creating doc/Makefile
config.status: creating doc/Makefile.comments
config.status: creating doc/html/image_src/Makefile
config.status: creating raster/Makefile
config.status: creating raster/rt_core/Makefile
config.status: creating raster/rt_pg/Makefile
config.status: creating raster/test/Makefile
config.status: creating raster/test/core/Makefile
config.status: creating raster/test/regress/Makefile
config.status: creating raster/scripts/python/Makefile
config.status: creating postgis_config.h
config.status: creating raster/raster_config.h
config.status: executing libtool commands
config.status: executing po-directories commands
PostGIS is now configured for x86_64-unknown-linux-gnu
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
-------------- Dependencies --------------
GEOS config: /usr/bin/geos-config
GEOS version: 3.2.2
GDAL config: /usr/bin/gdal-config
GDAL version: 1.7.3
PostgreSQL config: /usr/bin/pg_config
PostgreSQL version: PostgreSQL 9.1.0
PROJ4 version: 47
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.7.8
PostGIS debug level: 0
-------------- Extensions --------------
PostGIS Raster: 0.1.6d
PostGIS Topology: 0.1.1
-------- Documentation Generation --------
xsltproc:
xsl style sheets:
dblatex:
convert: /usr/bin/convert
topology; do \
done;
eval: 1: CC_quoted+= g++: not found
Again Thanks,
Nathaniel H Clay
